[WANTED] B&M flexplate balanced for 360 OR 360 balanced converter
RussellSullivan
East Liverpool, OH
I'm looking for a B&M flexplate, part number 10239. It's the one made for balancing a 360 with a neutral balanced converter.
They are in backorder from B&M.
I would also be able to use a lockup torque converter with 360 weights on it. If anyone has something available, I'd appreciate it. Thank you.
I’ll send you some pictures at some point today. I don’t know anything about it. Other than it was attached to the 91 roller motor I bought.
Looks like that converter is a dud. I’m not sure what the previous owner did to it. Snout is worn and the mounting lug was rewelded for some reason, and the wait was mucked up too.
Looks like that converter is a dud. I’m not sure what the previous owner did to it. Snout is worn and the mounting lug was rewelded for some reason, and the wait was mucked up too. View attachment 1715699333View attachment 1715699334View attachment 1715699335View attachment 1715699336View attachment 1715699337View attachment 1715699338View attachment 1715699339View attachment 1715699340View attachment 1715699341
That's a shame, because it was definitely a higher stall than the one I'll probably be running. I appreciate it though, thanks
Just curious, as it may be worth it as a core, how much would you let it go for? Plus shipping. I could see about getting it rebuilt in the future.
Shipping will probably kill the deal. I’ll let it go for $40 dollars plus whatever shipping is. It’s the factory high stall with the 103/4 flex plate. I have the flex plate to I’ll give you. But it’s been modified. It looks to me like it was a neutral balance converter and someone may have welded the weight on but I’m not sure. I don’t have any history of it other than I own it. You can see how the clearances the flex plate for the weight and hole for the bolt. All the teeth on the ring gear are in good shape so it maybe a good core to start with. I might even have some flex plate bolts lying around
Shipping will probably kill the deal. I’ll let it go for $40 dollars plus whatever shipping is. It’s the factory high stall with the 103/4 flex plate. I have the flex plate to I’ll give you. But it’s been modified. It looks to me like it was a neutral balance converter and someone may have welded the weight on but I’m not sure. I don’t have any history of it other than I own it. You can see how the clearances the flex plate for the weight and hole for the bolt. All the teeth on the ring gear are in good shape so it maybe a good core to start with. I might even have some flex plate bolts lying around View attachment 1715699575View attachment 1715699578
Well, I'll see what B&M says on the 5th. That's the date they told me my flexplate would ship. If they extend it again, I'll contact you. Just trying to use the available funds to push my project forward, though it would be a decent core to stow away. I won't waste your time getting shipping quotes if I'm just gonna use a balanced flexplate. Thank you.
