[WANTED] 1966 Valiant Signet driver side front fender fwd trim molding
Do you have a photo of the part you're replacing, or the one from the other side? I've got some extra moldings off a '66 signet.
I will locate the pass. side one take a picture and send it to you may take a day or two thanks for your respond Roger
length on long side is 9 3/4 in.
They sure look very similar right and left, but, IIRC, the front end is closed and the rear end is slightly open where it meets the wheel opening molding, correct? Here's the one I have that has those features. No clips however.
looks good to me how much, will need your pp stuff and you can ship to r buetow 1080 e john norman ln kingman az 86409 thank you good job. take care and no rush
