[SOLD] W2 heads, Cam, TTi headers Package deal
darto
Petaluma Ca
W2 heads 3870810 castings
One head has had a repair as shown in pictures. Didn’t hurt performance.
Has dual valve springs, bushed Roller Rockers.
In ok shape they do show some wear.
Removed from running car on 4/9/21
Package Includes
TTI ceramic coated headers with thermal coating for A body with W2 heads
They are scratched up and have a spot to gain clearance on the drivers side by the torsion bar.
Roller Solid lifters
ARP w2 head studs not pictured but included
Mopar w2 dual plane manifold
Includes 2 solid roller cams and the oil pump distributor gears
Lunati Cam
.636/.636 lift
272/272 duration @.050
104 lobe separation
Hughes cam
.570/.585
261/ 264 duration @.050
110 lobe separation
All of it for $2100 obo. I’ll ship if you figure out the logistics.
Located in 95403.
Is the repair between the 2 cylinders? And what's the cc's on them? Thanks.
I think the rocker are Norris.
the repair is between the two middle cylinders as shown in picture #3.
I think they are 70 CC heads but not sure.
Hello, have these heads been ported , also could you post a pic or two of the intake ports ? Thanks Red B.
I don’t think they have been ported. The intakes measure out at 1.32 x2.0, within a few thousands of the intake manifold.
Part number TTi-340AW2-C4
They are ceramic coated with a thermal barrier.
Bolt spacing is 3 15/16
1 5/8 to 1 3/4 tubes
price is $550
