65 tank?
pishta
I know I'm right....
Tustin, CA
Does this look original or 1971 replacement? Taken from my barn find '65 with '76 tags.
Its coming out for the new AMD 1963 flanged tank that looks like a direct fit with a slightly different gasket only. It's fitted to a flange on the tank instead of free floating on the filler tube.
Update: AMD $36 tank is identical to one I removed. Even the flange is the same once the 63 style gasket is removed.
A likely irrelevant observation is the insulating material looks like roofing felt or tar paper from the white lines on it.
Its about 1/8 thick jute. looks pretty good for 55 year old under the car insulation! You think that old tank is a 71 production date replacement?
I cant speak with authority about the tank, but when I transferred the tank from the 66 Dart donor to my 65 Bcuda the insulating ‘blanket’ didnt have any lines and looked far more weathered while still serviceable.
