[SOLD] New, never used electric fan
dusterdoug
Tracy, CA
Cooling Components #CCI-1730...has 2 speed motor. Google it for more info.
I ordered the wrong fan, and after a year...no refunds. My bad...lol.
Paid over $400 shipped...
Do I hear $275, shipped??
Thanks for looking.
22" or 26"
fan assembly is 18” x 20”.
CCI-1730
If you don’t have 2 5/8″ clearance behind your 30’s car radiator, 1730 is the slimmest CCI fan & shroud, where most water pumps sit it needs only 1 9/16 ” clearance, Two speed hi-output motor, 17″ ultra quiet blade
WIDTH : 18 ½″ MIN.WIDTH : 15 ½″
HEIGHT : 20 ¼″ MIN. HEIGHT :
Do you happen to know the CFM Rating on this one, the website doesn't even give this information, wasn't sure if it included in the paperwork that came with the Fan.
I do not, sir. I’ll call them in the morning and add that to this ad.
There fans are 2500 true CFM, I had a problem with a 400 chevy in a model A, this is the only fan that kept it cool. I got a air flow meter and all the 3000 cfm fans I got, only flowed 1500 CFM, this fan flowed 2650.
Thanks for the input Brian. A buddy had the same issue with his stroker small block in his Duster. Spent a month researching fans and airflow and concluded these were one of the best out there. His cooling issue was immediately solved.
