[SOLD] Duster Stuff
RustyRatRod
Caput villa stultus
Georgia
I recently acquired some Duster stuff. To be perfectly clear, I have very little Duster knowledge. Everything was supposed to be either for or off a 1972 Duster. Some things may or may nor be. I have no idea. As such I'm pricing this stuff what I think is very reasonable. This is the first "load". There will be more. Send a PM if you see something you want, as I may miss it otherwise. Whatever will fit in a flat fate box will get shipped flat rate. Whatever will not, I will ship the cheapest way possible. Parts located in middle Georgia. Thank you drive through.
Clusters 50 each plus shipping.
Headlight buckets complete with headlights....may or may not work, lol 20 each plus shipping. SOLD
Sill plates.....one has a dent.....25 for the pair plus shipping.
The small, short about 6" long whatever it is trim 15 plus shipping. SOLD
The longer trim whatever it is under the sill plates 25 plus shipping.
Glovebox door...no lock.....25 plus shipping.
Hood latch frame......35 plus shipping.
Spring hanger and shackles.......45 plus shipping. SOLD
Quarter pop out window......75 plus shipping.
Blower motors......10 each plus shipping.
Wiper motor......15 plus shipping.
Washer tank...it has the pump but it's missing the attaching screws.....25 plus shipping. SOLD
One condition. I'm slow to ship because most weeks we only go to town one day. We live in a very rural area and caint afford driving all over God's creation. So if that's a problem, then you probably need to pass. But if you buy from me, you WILL get your stuff. We normally get stuff gone pretty quick, but if it's after we've been to town for the week, there might be a few days before I get it out.
The 6” trim goes on the sill between the back of the door edge to the rear seat. The complete cluster is newer than 72.
Wide trim by the sill plates looks like rear window trim, maybe?
Thank you! Like I said, I don't know jack diddly doo doo about Dusters.
I might be in on the small trim pieces and possibly the glovebox door. Do you have a better picture of the door? Any dents or issues that you notice with the metal?
The glovebox door and little trim pieces are perfect as for dents.
It's not letting me upload the trim pictures. I keep getting a "security warning". But they're perfect for dents. They just need cleaning up. I'm assuming you mean the short like 6" long trim, right?
Let me check on the clove box door. It looks different than the one in my 70. Maybe the trim level changed. Yes the short pieces. Thanks
Ccordin to what I'm seein the door is the same all the way to 76. This one is plain and some had trim. The basic door is the same.
I need a 1973 headlight bucket. Let me check my one bucket that I have to compare.
If it is the same I will take it and pass on the light bulbs. Just need the buckets.
If you could post a detailed pic of the buckets I would very much appreciate it.
Here you bees. I just need to know which one you need. I don't know how to tell them apart. I'm sure you do. As for the bulb, unless you just don't want it, it's comin in a medium flat rater, so you might as well take it. lol But it's up to you.
[QUOTEw="RustyRatRod, post: 1973506123, member: 14960"]Here you bees. I just need to know which one you need. I don't know how to tell them apart. I'm sure you do. As for the bulb, unless you just don't want it, it's comin in a medium flat rater, so you mig
View attachment 1715755131[/QUOTE]
It appears that there’s a difference.
This is a 1973
This is a 1973
View attachment 1715755133[/QUOTE]
They do look different don't they? I'll see if I can find what the 72 and back looks like. Thanks for helping to narrow it down.
This is a 1973
Hang on now......look at the buckets in the buckets on mine. Those appear to be the same. The outer bucket is the part that actually bolts to the CAR. What you have pictured is the actual bucket the headlight sits into.
This is a 1973
Hang on now......look at the buckets in the buckets on mine. Those appear to be the same. The outer bucket is the part that actually bolts to the CAR. What you have pictured is the actual bucket the headlight sits into.[/QUOTE]
Heck, I’ll try it out. You take PayPal?
Heck, I’ll try it out. You take PayPal?[/QUOTE]
I do.....but I'll be glad to take one apart to make sure. I don't want you buyin somethin you don't need and caint use.
OK. Now we need to determine which one you need. Or do you want them both?
If they are not the same, side to side, I don't know which side I need so I would take both.
Definitely the second set you showed though.
As far as I know the part I am looking for sits in the part that is spot welded to the fender/ core support.
