My Demon has a spun outer wheel bearing race. Is there a fix or a place to buy new hubs/drum assemblies for 10" drum brakes? Speedy sleeve maybe?
This is what I have done. Make a bunch of punch marks where race sits in hub. Clean hub and race with acetone or lacquer thinner. Apply loc-tite primer and allow to dry. Apply red loc-tite. Press in race.My Demon has a spun outer wheel bearing race. Is there a fix or a place to buy new hubs/drum assemblies for 10" drum brakes? Speedy sleeve maybe?
Blue Loctite melts at around 400-450F. I would think that a bearing race would get at least 200 or 250 max as long as it's properly greased?I had thought of that, but the Green loctite would be the correct one for the application. That is for cylindrical bore / sleeve retention.
