[SOLD] 67 318 long block
No name needed
Pa.
from a camper. Had 54 k on clock. No ridge wear.on cylinders.checked standard bore.block line bored, magnifluxed.new cam bearings.hastings rings,10 10 on crank.Clevete 77p bearings.
Crane Energized 272 454 lift cam, 273 adjustable rockersBanna grove rocker shafts,double roller Edelbrock timing set crane Hyd lifters ,new water pump 714 heads teflon valve seals standard valve job Melling oil pump. Changed course going with a 408 striker. Less then 200 miles on build.
Coming from Cali. To Carlisle. Possible delivery depends on time and buyers location. Or pick up at Carlisle next month.. valve covers and intake not included. Avaliable. Separate. Pm any questions.
$ 1,500.00. Crated up ready to go. Currently in San Diego area.
What do you think hp would be?
Around 250. Stock 230. With headers and different intake, might get up to 270. Just an educated guess...It has factory cast iron heads.....And stock pistons. 67 was more desirable in that the piston height, compared to the deck, is favorable. Not to far down in the hole...10 to 1 comp ratio...I cc'd the heads, 62 cc. 714 heads are same as 302 heads. Casting number. Swirl port and hardened seats...
