Stop in for a cup of coffee
Assembled steering gear. I wouldnt use it in my truck.
back to the drawing board.
I had to grind end of shaft to get it through wheel hub. 2nd one is a groove worn into shaft due to a missing bearing.
If anyone happens to find a dodge Dakota 6 speed manual from a 4.7 4x4 near them, let me know
So what's a good radiator flush??
I got a free ford ranger with the aluminum radiator but the cast iron block and the coolant is dark red sludge, prolly the original stuff in there.
I heard somewhere that vinegar will clean that up??
What says yous guys
What says yous guys
what year? Is it new enough to have the new red coolant or do you have a trans leak in radiator? Demon had that after MITP trip.
What says yous guys
I’ve always just used the radiator flush stuff you get at the parts store
What says yous guys
Vinegar is a very good cleaner. I use Vinegar and dish soap to clean sinks and showers at home.
What says yous guys
Vinegar cleans lots of things. What could it hurt to try.
Nah it's not ATF because it's a rusty red and it's a manual transmission truck so there's no ATF in the radiator anyway
1995
1995
Gunk, heavy duty cooling system flush.
I did use simple green to clean a cooilng system after a cooler failed. That stuff did a fan tastic job!!
Transmission failed 3 months later.
Our track owner has a thing for music events over racing it seems, more $$$ in his pocket I suspect. Just one problem, his neighbors knew they were buying next to a racetrack when they moved in, track was there long before housing. Residents accept race track noise, they have issues with the musical events. Little thing like the concerts don't have to meet the 95 decibel cap as the race cars do :wtf: and they have no problem letting the county sheriffs know of their dislike. :lol:
I used to live 1/2 mile from the Detroit State Fairgrounds...
I could hear the music from my front lawn... If I liked it, I stayed outside and listened... If I didn't, I went inside...
No need to complain...
Thankfully trans psi is higher than coolant psi, so just ATF in water. Changed radiator and is all good.
Still sucks though. But that’s one reason I went with a manual radiator in the Polara. That and I put a stand-alone trans cooler in front of it from a 2md Gen Cummins. It oughta stay nice and cool
I THINK 2 truck cabs and a 8ft bed. There is a guy near Hoppy, who owns a surplus business, and he restores cars. Quite an operation. He has "stuff" hear in So Cal he needs there. This would be third load for him...
That moment when you buy more fireworks than you can stack in your Jeep
