Hemirunner
Once you get that sorted, it’ll be an animal! Those S475s are beasts, especially on a G3. I’ve got some sort of parasitic draw on the battery. It’s dead inside of a week.
that sucks. maybe a stuck relay or a bad battery?Once you get that sorted, it’ll be an animal! Those S475s are beasts, especially on a G3. I’ve got some sort of parasitic draw on the battery. It’s dead inside of a week.
I understand your frustration. I get like that also and wanna sell some projects or just everything. I think it’s wise to just take a break for awhile. Dustinthat sucks. maybe a stuck relay or a bad battery?
i lost all ignition on mine for no reason what so ever. have compression, fuel but no spark at all. checked my fuses and relay swapped out no change. to exhausted to consider messing with it anymore. bout to sell it dirt cheap now. it is time. new wiring x3 and never functional. im done with everything and pretty much sick of cars in general. i get it now why there are so few 1 man shows in heads up racing. its a damn job to just keep it running for christ sakes. uggg
You’ll get it figured out. How is power routed to your Holley ECU? On mine, it’s the only thing that’s not run through the battery disconnect switch.that sucks. maybe a stuck relay or a bad battery?
as holley instructions require. power/ground to battery post and remote power wire to ignition key on, to a dash mechanical switch. i get fuel, have compression but no spark. cant be power but maybe a ground? ive not checked that yet. been feeling pretty bad physically since i got back. tried friday tnt and it sucked the life right outta me. 3am bedtime is 6hrs to late for me. hahaYou’ll get it figured out. How is power routed to your Holley ECU? On mine, it’s the only thing that’s not run through the battery disconnect switch.
we've all been there, sometimes you can't see the wood for the trees. at least (or at last, lol) you found it.she runs again as of minutes ago....and i am retarded. popped a fuse to the coils. swore on my life i checked and double checked....apparently with my eyes closed and in the dark.
Mine still needs work LOLshe runs again as of minutes ago....and i am retarded. popped a fuse to the coils. swore on my life i checked and double checked....apparently with my eyes closed and in the dark.
only with help from rick trunkett of "big 3 racing" in ohio did i resolve the issue.we've all been there, sometimes you can't see the wood for the trees. at least (or at last, lol) you found it.
So is it revving cleanly now? What was the issue?only with help from rick trunkett of "big 3 racing" in ohio did i resolve the issue.
[QUOTE="Hemirunner, post:
see post 632 aboveSo is it revving cleanly now? What was the issue?
Yeah saw that... I was referring to his original problem of dropped crank signals...see post 632 above![]()
nah. im used to it now. time to turn it up and work on the boost controller sife of things. as it takes 2.4 seconds into the run to get to 10psi. id like that to be a lot sooner now.Awesome! So after plugs then the hope is just working on the driver mod and getting used to it?
Glad a d you got it figured out. That’s huge gap.i was blowing out spark. tonight i closed the gap on my plugs(lol look at pic) ordered another different hest range plug as well. 1st pass it literally died on me about 100ft out 1.43 60ft
2nd pass 6.33@112mph
3rd pass 6.12@112.90mph
last 2 passes i was able to reach 6krpms before the spook the cars built into me and short shifted. regret it cuz the car was really pulling in low gesr unlike anything its done before. so there is some big promise after tonight. thst i got it fogured out.
never run a big gap on a boosted car. turbo car instructions 101. some how i fucked up the plug gap by using feelers. this time i used actual spark plug gapper. down from .071 to .020..doh!
