402ci Custom S475 A2W Set-up
AirForceRacer
Mopar or No Car
Indio, CA
Finally got my Duster back home...
402ci Stroker with a custom A2W Borg S475 turbo set-up.
Is that green thing the air filter? How many microns is that?
That's one sick build, great job. Nice looking air water off to the drivers side, custom? Going to wrap all that nice pipe work or get it coated?
Thanks everyone! Its more of a screen and not a filter for the turbo. Yes the entire set-up is custom. My buddy at BK Fab did the entire set-up to include the Air to Water Intercooler with the pump and tank in the trunk.
The car is a monster. No idea on power number there are no local dynos Id be happy with 600rwhp.
You would have to take the engine out of the car but IMM (Indio Motor & Machine) has a dyno. Don't know if you know Fred and Brian but they know a little bit about LA engines.
600 HP is probably a conservative estimate, it looks like a real tire fryer. Hopefully you can get the suspension sorted out so you can put all of the power to it & make it hook.
What suspension are you running. How is it going to hook?
Right now its stock everything. Looking at different set-ups.
Good to know. Id rather not pull the motor and find a chassis dyno.
Yeah that is defiantly a priority getting the power to the ground.
