[WANTED] S.B. solid camshaft wanted
1966Post
Wisconsin
Wanted: looking for a small block smaller sized solid lifter camshaft like a Comp 270S or Isky E4 nothing over 224 duration 470 lift New only Thought I'd check with the group before getting on the 3 month waiting wagon
Thanks FABO
Thanks FABO
If you dont find one here look on ebay
put in [Mopar Performance] I seen several for LA this week
There is one (1) in stock at one of the NPW affiliated locations at "location 5", which I think is in Rhode Island. I'll try and get an address tomorrow.
Go to Howards or Hughes they have some small solids for $175. You will also need springs, probably pushrods etc. If you buy new go to Hughes for break-in procedure. A lot of failed cams nowadays from people just sticking it and starting it up.
