A TA “tight” 10” would be a pretty good compromise converter for the OP’s combo.
I’d expect it to have a true flash stall of 3500-3700 behind his 512.
Next step up would be something like a tight custom 9.5” from PTC or UCC, but frankly....... those might end up being a little loose for the OP’s [email protected] cam.
Kent,
Cannot your specific question but wondering how you like the TF single plane intake.
How is the low/midrange power?
Idle quality & idle rpm with that cam?
Thanks.
Anytime, I appreciate the help.
Idle is set to 950rpm by the EFI tuner. I had it at 850 but he said to bump it up. It is not a lumpy cam but it sounds great to me. I can get a video of the idle on the weekend and will post here. Power is hard for me to assess as this is my first and only muscle car. What I can tell you is that it moves when called upon at any speed on the streets. No hesitation at all.Kent,
Thanks.
Thanks Bob, I like how my TC handles street performance. I have not heard compelling evidence that it would be worth it for me to change what is working right now. Next year when the Drag Strip reopens, I will see how it performs. Maybe then my needs will be different and I will make a change.Kent, I `ve kinda followed ur build all the way thru, since its so close to mine . Looks great to me !
This is at idle and a little throttle up to 3500 rpm.Kent,
Thanks.
https://youtube.com/shorts/pZLMZJbjWfM?feature=share
Kent and Bob, this is a classic example of a car needing a custom converter. The Hughes converters are old slush box technology. The new technology converters will make u think u added nos, a supercharger or turbo to ur build. Night and day difference. Everyone builds the engine and rear and then cheaps out on a converter. It’s the single most important upgrade u can do to ur car. PTC, Ultimate, Dynamic or Precision of New Hampton are ur friends. Be totally honest with them. I agree a 38-4200 will make ur car a force to be reckoned with. U will be very happy. My 9.5 inch stalls at 4200 and drives like stock in town and on the highway. At the track it’s awesome. Kim
It will be the best money u ever spend on ur car bar none. Kimguess I`ll start saving the coin for that too----------lol
The other thing is this.....you cannot really get an accurate measurement of stall but one way. That is if you have a manual valve body, with the car in high gear at a stand still and with your foot FIRMLY on the brake pedal, parking brake set if it's operational and slowly run the RPM up with it in high gear sitting still until you note where the tach stops going up. Whatever RPM that is, is your stall speed.
You can certainly do it in high gear rolling as described, but it will not be anywhere near as accurate.
And Kent, this isn't meant at you, because I think you get it, but there are a few in this discussion still thinking old school and confusing "loose" with "flash". Those are two totally different terms when speaking about converters, and modern technology has all but eliminated "loose".
Kent I would not change a thing it looks like you have a really well thought out setup. The 512 is a torque monster you do not need a high stall speed converter to go out and have fun. If it were a purpose bulit race car it's a different story.Anytime, I appreciate the help.
it gets u outof the hole but only if u brake torque it i use to have a 73 polara with s cammedc 400 it had a high stall convertor but i when back to stock i got 2200 out of itThis is the status of my car as it is right now.
1973 Plymouth Scamp
RB 512ci, 440 source stroker kit with lightweight crankshaft, forged pistons, 10.83 CR. Trick Flow 240 heads, 440 source aluminum rockers 1.5RR, Trick flow single plane intake. Holley super sniper EFI, hyperspark ignition, coil and distributor. TTI 2 inch headers. Hughes 3000 stall converter. 727 transmission with transgo tf2 valve body mods. B&M Quicksilver shifter. Gear vendors overdrive to 8 3/4 rear end with 3.91 gears, braced in back. SS leaf springs. Competition engineering race shocks. Pypes exhaust 3" into 2.5 inch. RacePro mufflers. Mickey Thompson ET street SS Drag radials 255/60-15 27.3 inch) but going to 275/60-15 28.2 inch diameter. Current cam specs 244/252 @ .050”, 282/290 adv, .516”/.537” lift(1.5:1 rocker), 112 sep, .016”/.018” lash, Solid lifter from Oregon Cams.
Both Ken Heard at Oregon cams and Steve Magnolo at Hughes converters recommended a 3000 stall converter. Ken said "3000+" Steve said 3000 for street/strip and 3500 if mostly strip.
So I have the hughes 24-30HD Hughes Performance 24-30HD: Heavy Duty Pro-Street Torque Converter for Mopar A727/TF8 & A518/46/47RH | JEGS
My question is more of what does having the 3000 stall converter give to performance on the street versus the 3500 stall for the strip? What, if any benefit would the 3500 stall do? Are we talking 2 tenths of a second in the quarter or 2 seconds in the quarter? How does the 3000 stall make it better on the street? What would you notice?
FWIW, My intended use is mostly street and next year hopefully the track reopens in Spokane. then about 8-10 trips to the track. I am not competing in any class. Just Friday test and tune.
I have tried to "Google" the differences but I have come up short in my search for the differences. The answers I get are use this stall for this application and that stall for that application.
IMO, I call this a hell of a setup, with that engine in that little car, .2 sec in a 1/4. I could see 9's at 125, I say a lower trap speed as those short tires could hold speed down with your gears. Now if you intend to only run 1/8th, not a big deal if the car is a street/strip. Stall speed is nothing when you can't hold the rear tires from cutting loose. On the street you will be wasting rpm and making a lot of un necessary heat in the transmission. Now for street driving leaving stop lights converters have what is called a flash point rpm where they allow engines to briefly hit an rpm much higher than the stall rate. The ONLY reason for using a higher stall speed is to get the engine rpm closer to the lower limit of the power curve under any and all conditions. If you are running a trans brake and you have a cam that starts in at 3800 you would obviously want a converter close to that. Not advisable to go over because then you would be wasting torque and drive at the bottom. If your engine is happy idling at 1000 and power curve comes in a 3.2k I would be perfectly happy with a 3k or for that matter maybe even 2.8k if the car is a streeter. Having a converter with a higher stall lets you put it in gear at idle much easier as it will not load down the engine at lower rpm. Having a stall higher as I mentioned, at lower speeds you will be in a mode I call freewheeling where the engine is just running along basically wasting fuel and not pulling. It's like going down a hill with your foot on the gas, filling cylinders with fuel and not using that fuel to make power, you don't need it ! Of course if you are goin down a hill with a high stall, you won't have much engine braking affect either, you will simply coast along gaining speed until the rpm go up above some point of the rated stall. This makes you use your foot brakes more or shift into a lower gear and that's not good either. At one time many years ago, I was running a 440 with a cam that came on around 3.4k not a big cam but not a stocker either, it was an Erson grind. I was perfectly happy with it for the purpose, my car was a driver and would run mid 12's with street tires. I had a fair bit of work into the heads, intake and using 1-7/8 headers. I used a stock 11 inch 727 converter at the factory rated 2800 rpm. No trans brake and could cut a 60 ft time of 1.6 sec. The car left the line like it was shot from a rifle as long as I could hold the tires. Usually that was impossible and even blowing away, I cut the times. I never had a chance to run on slicks or real drag racing tires. I did spend some time around a few guys that were points champs for the S.W region of the nation while I had this car and they all were impressed with it for what it was, they did not expect it. Told me if I swapped on a set of 30 inch x 9 or 10's it wouldn't be likely to see the times reduced to near 1 with 1/4 knocking on 10's because I was smoking thru the lights in 3rd gear. That car was geared with 3.55's which only enforced the issue that everything worked good. I didn't have to sacrifice anything and although I would have liked to swapped in a set of 3:91's which would have necessitated a new set of tires for street use of much taller and that would have caused issues with rim width and off set. I didn't want to go narrower.This is the status of my car as it is right now.
1973 Plymouth Scamp
