Sean Officer
1967 Dodge Dart 270 2DHT 360 Magnum/A904
I am really trying to document before and after stuff. I really want to get it cleaned up, apart, and check for the things that need replaced. Already doing new gaskets and seals. I am also considering trying to figure out how I can do a citric acid flush of the cooling system. I need to check out the effects on cast iron though. I know with steel and stainless it creates a protective coating that resists rust. It is something we do at work on large scale cooling systems. Will see if it needs new bearings or cam once I get it apart. The engine only had 86k on it. Not too bad for a 54 year old car. We've decided to keep it original for now. May convert it to a Charger/Commando in the future. Who knows?
I was hoping to get by with a hone and not have to bore it out. Cam is shot. Looks like the dog got a hold of it. I am not sure if the discoloration is normal for an 54 year old cam/lifter set. Going to pick up a puller for the harmonic balancer tomorrow after work and try to get the lower portion apart and get a look at the bearings and journals.
is the perfect size to clean out the valve guides. Just make sure it has copper scrubbers on it. I hosed it with brake cleaner to clean it out, then WD-40 and ran it through a couple of times, working back and forth once the scrubber was through. The scrubber is designed to go through one way so don't try to pull it back through. Leave some slack in the side you are not pulling on to keep the snake expanded in the guide. They came out beautiful and once the valves were cleaned and installed they moved smooth as butter. Also got the crankshaft and number one piston installed. Took my time with everything making sure it was all super clean. The lacquer thinner worked great. Probably won't get to more assembly until next Friday as work takes most of my time during the week. I had a load of fun though. way better than just cleaning parts.
