Mr. Sinister
Devastation Manager
Great thanks shipping to 48048 Michigan let me know.
Thanks just let me know and I appreciate the added effort.Found the one...it is in one piece...will look for the other .....and see if I can find it....
Did you find that longer one you needed?While waiting for carb to show up...i got a oil dipstick and tube to fit......
Ok...drove it around the block......made it back under its own power....got a few issues...
holley 1850 carb sucks
header gasket leak on passenger side.
trans kick down linkage needs adjustment
Alternator is over charging....
need to get rid of clutch pedal
Well...Tuesday is got closer to the dump but the fuel pump is wired there a relay with a circuit breaker.....and the circuit breaker died...LOL...My daughter towed me home again....
Got rid of the circuit breaker and wired in a 30 amp fuse plus I have spare fuses.....the HEI module is hell of a lot better then the old mopar ECU......
