73 Duster collapsible steering column bushings
Jetnoise
Quando Omni Flunkus Moritati
Northern Nevada
Hi,
I'm rebuilding the column on my '73 Duster, and in the course of my adventure, I managed to pull apart the 2 halves of the telescoping steering shaft. On the inner shaft, I found 2 broken "bushings" that ride in the 2 grooves near the end of the shaft. (see photo)
Any idea where I can find a replacement for these?
Thanks!
-Sean
Hi,
Thanks!
-Sean
Those aren’t replaceable. That was actually injected under pressure when the shaft was made. The purpose was so they would shear during a hard frontal collision and the shaft would collapse and supposedly cause less injury to the driver.
Thanks for the reply! That's what I was afraid of.
So it seems like it wouldn't make much of a difference if I ran the column without them installed, or am I missing something?
This is always a controversial subject when it comes up, but yes, there are many mopars running around like that.
