Hey everyone, looking for some help comparing 2 cams. Building a 5.9 mag for my D100. I was thinking about going with the Hughes SER1822ALN-10, it’s a long snout cam with 218/222 duration @50 on a 110 LSA, installed 106, 539 and .549 for lift. Cam events are intake opens 3BTC and closes 35 ABC, exhaust opens 45 BBC and and closes -3ATC. I see 318willrun’s build with a similar cam in his truck that has my attention. It’s a Oregon grinder cam #1634 with 218/224 duration at 50 on a 110lsa, installed at 106/114. Cam events are Intake open 3 BTDC and closes at 35 ABDC, exhaust opens 46 BBDC and closes -2 ATDC. Lift is similar but a little less in this cam.
I don’t dont how to compare cams other than duration @50 and lift, and these cams are close in that regard. Any help with the cam events to compare would be great.
build is 5.9 magnum with fresh hone from the machine shop, square decked with pistons down the hole about .047. .028 head gaskets with EQ heads with 2.02 valves, Hughes springs, good valve job and bowl blend. Eddy air gap rpm for LA, and a 670 Holley. Gears in the truck will be 3.73 with 28.8 inch tires and a 518 OD trans.
converter will be bought last to optimize set up.
Any help on figuring out the the differences between the two cams for my application would be awesome, thanks everyone.
