[Found!] Heater motor ring thingy
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
I am looking for the ring that goes on the firewall side of the heater motor for non a/c.
It's round and has one flat side and attached with 4 nuts. If you have the nuts, I'll buy those too.
For a 72 demon, so it has 4 bolt holes. Should be the same as any 67 to 72 non a/c cars
It is actually a ring with a seal on it so the motor won't rattle on the firewall when it is running. I have a few dozen of them if you can't find one locally, like you said it is the same from 1967-1976 on non-A/C cars...
Except 73 up don’t use the plate. Kim
