My new engine puts out 450+hp/520+lb-ft at the crank. I’m planning on proceeding with the A904 but I understand this is close to the generally accepted safe range for this unit.
What is the typical failure mode for these transmissions? When do they typically suffer their failures? I always assumed that the moment the tires grab after a burnout was the killer but I don’t know that for sure.
Back before I installed my last engine swap (300hp small block) I had the local shop rebuild it with upgraded bands and clutches, higher RPM governor weight, shift kit. Maybe some other stuff? I can’t remember. It was a while back. I also installed a deeper pan. I’ve been running the cooling lines through the (upgraded) radiator but I may add an external cooler for some extra insurance. I’m pretty sure I also bought an upgraded sprag but I can’t find my receipt for that part so I’m not positive.
Not sure if this makes as difference but im running a mild 2800rpm converter, 4.10 axle. I don’t plan on running drag slicks but I will be on 200 TW summer compound tires this year.
I guess I’d like to know how to be kind to this thing and minimize the conditions that kill them until I’ve saved up enough cash for the manual swap.
Thanks!
Thanks!
