I have a 1973 scamp.
RB 512ci, 440 source stroker kit with lightweight crankshaft, forged pistons, 10.83 CR. Trick Flow 240 heads, 440 source aluminum rockers 1.6RR, Trick flow single plane intake. Holley super sniper EFI, hyperspark ignition, coil and distributor. TTI 2 inch headers. Hughes 3000 stall converter. 727 transmission with transgo tf2 valve body mods. B&M Quicksilver shifter. Gear vendors overdrive to 8 3/4 rear end with 3.91 gears, braced in back. SS leaf springs. Competition engineering race shocks. Pypes exhaust 3" into 2.5 inch. RacePro mufflers. Mickey Thompson ET street SS Drag radials 255/60-15 27.3 inch) but going to 275/60-15 28.2 inch diameter. Current cam specs 244/252 @ .050”, 282/290 adv, .516”/.537” lift(1.5:1 rocker), 112 sep, .016”/.018” lash, Solid lifter from Oregon Cams
I currently have a
1. QA1 k member and dynamic strut rods
2. Comp engineering shocks all around
3. PST 1.03 torsion bars
I will be changing to
1. Viking double adjustable shocks all around, They arrive tomorrow.
2. 892/893 torsion bars
I have learned much about the front suspension since I first assembled this car from scratch and I may not have been as diligent with the details of assembly. What I would like to know is, If you were going to assemble from scratch, in what order and how would you do it.
My concerns are.
1. How to adjust the QA1 dynamic strut rods? They are in place but I did not adjust them. Do I do this without the shocks and brake calipers on or off? Suggestions.
2. torsion bars before shocks or after shocks?
3. I have read somewhere that you need to install something, and get the suspension weighted before you adjust and tighten things but I cannot remember what that was. Control arms, bushings, torsion bar, ride height. I cannot remember.
4. I also remember reading about rubber vs poly bushings, advice?
So many parts and I want to be systematic about it this time. I have a FSM but the sequence is not there. I can study the how to on many items but where do I start and in what order do I proceed? Of course in the end, I will set ride height and Align.
I currently have a
My concerns are.
