bigus1949
With a 2245 holley carb. I need info on hooking up the throttle and kick down cables. Seems no one makes a kit for the 2 barrel carb.
A) The bolt patterns are too close for a simple adapter, the holes would overlap. I used that carb on My Killer6 part II, 3/8" thick aluminum plate w/the holes in stk. location on the Dr. side, (2) counter-sunk screws at the stk. location on the Pass. side, & 2 studs at the new pattern further inboard on the Pass. side. I then slotted the holes in the 2245 base on the diagonal into the stock BBD positions, & ground out the intake base to an open oval to match the 3/8" plate.sure they do. A 2245 is the bigger 2 barrel made for a 360 or 400. Wont directly bolt to factory super 6 intake. They make adapters to go from the small 2 barrel pattern to the bigger 2 barrel intake pattern but then you might have hood clearance issues, and the linkage (especially kickdown) is gonna be a nightmare.
A rod was used. Be great to find one if you could. It would make it easier.With a 2245 holley carb. I need info on hooking up the throttle and kick down cables. Seems no one makes a kit for the 2 barrel carb.
