[WANTED] 383 standard piston s
Good used are fine
Forged are crucial for his build.020 or 030 myt work
Hes low on $$
Tim @52537
Thanks Kim
He bot a413 hp s coda at Indy
and he need’s some options
426 mw factory piston s would work
I’ve got a set of 2293 trw s if it comes to it
Thanks. Sweet. A 426 piston will not work as the compression will be way too high as it’s designed to be used with a 6.76 rod. 383s use a shorter rod 6.535 I believe. I have milled the pistons flat and ran nos with them. Their a strong piston. Kim
