I am using ebody bucket seat frames but installing abody foam an covers , upper part of back of frame in picture its the rod welded width wise up towards the top around 10 inches from the top , were you tie in with hog rings to line up the seat cover area crease in material , the top picture is of an actual abody frame but mine in the ebody frame the rod appears a little different an higher , I assume I need to lower the rod to match in picture ,,my question is this the only difference ? It is as far as I can tell but the covers haven't arrived from legendary yet so I can compare ,,the 2nd picture is of the ebody but havent cleaned off all the glue an foam yet but you can see rod is a little different but everything else looks the same
