Pushrod Adjuster Size
Les Gibson
Sabattus, Maine
Good morning all,
Apologizing in advance, but my old timer's disease is kicking my backside this morning. I'm trying to order a set of pushrod adjusters and lock nuts from Smith Brothers to fit the Norris stainless W2 roller rocker arms that I have. My problem is I can't remember what diameter the adjuster screws are, and I'm not at home to be able to check. Are they 3/8 diameter or 5/16?
Thank you!
Good morning all,
Thank you!
The threads are 3/8. There are a couple of different radii balls. Actually there are three. One is big enough you have to screw the adjuster in from the bottom. I used those whenever I could.
Thank you! you have saved me from certain doom!
