roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,808
- Reaction score
- 3,590
Barra,
If you really wanted to see what worked best in your engine, you would probably have to try a few cams & spend the $$$. DV did just that. Tested over 19,000 cam combinations at Crane cams....& more. From that he derived the 128 rule, which you will find on the web. Works for street CRs & parallel valve heads.
The last thing you want is a cam with 112-114 LSA. Too wide. 106 would probably be ideal but a shelf grind with short enough duration might be hard to find.
The 128 rule is for finding the ideal LCA, not LSA.
I'd agree that in this case, with the OP's goals and engine combo, the narrower LSA is more ideal. A wider LSA has it's place, but would depend on the combo and the goal.
