Mickey Thompson Drag Radial Actual Dimensions
12many
SC
Need to know if possible what the actual dimensions (not the specs that are shown in listings) of MT ET Street R or S/S in 275/60-15, and 295/55-15 mounted but unladen.
Specifically “section width”
And on what size rim you have them on. Any info greatly appreciated!:)
Ive got 295/65 R15s....on 10 inch wheels.
295/55R15 is that correct?
Specifically “section width” View attachment 1715909192
I have the M/T ET Street S/S P295/55R15 mounted on an 8" wide rim. They're pretty close to 12" wide if you lay them down and put a straight-edge across them like in your picture. They actually came out right about at the specs they list on their website.
I use them when the car is street-driven.
I’ve got 8” wide rims as well. I know the 275/60’s are the better fit for them, but the 295/55’s would work. I’d prefer their slightly lower profile if I can fit them. Any pics of the sidewall bulge showing some of the rim? And how much tread do you reckon is making contact on pavement? (assuming you are running them now)
Running them?? No running anything here -we're still in our 8 months of winter!! However, the tires are on the car which is sitting on my trailer for the winter. Here's a pic - best I can do. I'd say the contact patch is about 9.75" if I lower the air pressure back down from the 35 psi or so for the winter. That 4x4 is up against the side of the tire for your reference. Hope this helps you!
@lead69
