4spd-Shifter
Is the 6 cyl. K frame the same as 318 K frame?
thanks-
thanks-
No, not the same.
6cly A body K frames have different motor mounting locations than the SB (V8) K Frames, BB (V8) K frames are different as well in other areas.
67 is a Unique K frame /6, SB V8 or BB V8 due to the Idler Arm type, 68 through 73????? SB V8 K frames are the same and use a biscuit type insulator. 74???? through 76 SB V8 K frames use a different engine mount and use a spool type insulator
It’s the passenger side that is different. KimIIRC; as to engine mounts, between slanty and SBM, only the driver's side is different. You can cut it off and move it, but IDK if it can be reused without modifying it. Ima going from memory here ......
68 to 72 are biscuit-style, while the spools came in 73. Big-blocks use different mounts again. As mentioned the 67 has a one-year only idler-arm mount.
