[Found!] Mopar 360 Engine Block
SMCARNUT
Streetsboro Ohio
Looking for std bore 360 block casting number 3418496 I would prefer 70 or 71 castings dates. I would prefer something close so that I can pick up. I am in Ohio Zip Code 44241.
I think I have one, but I am in se Pa. I will double check the date. I checked it, casting 9/14/70, standard bore, sonic checked at zip 19464.
If they are early blocks with 34xxxxx casting that are standard or 030
they are worth $500.00 and often much more to a Stock/Superstock Racer!
Very Hard to Find Anymore!
Only thing I would worry about is 99 chances out of 100 it is
a later year block = That is a concern if it is overbored very much and
not a 34 block. I have had several late blocks (77 to 80) that did not sonic
well enough to go 030 (really not even 020).
However, that is a good price even for a Cast crank Stroker.
For what I do = I would be concerned about quality of assembly and machine
work but if you are just doing a basic street driver it would not be critical.
I have an early 360 short block in storage bldg. I will have to get over there and write down the numbers for you. I'll have something early next week and I am close to you. I also have a complete running 77 360 out of a 3/4ton pickup.
I have had issues with this site. I don't see 1 post to you.
Your inbox is full. Click on it and delete unwanted conversations so he can send you a message. It's in th upper right corner by the search box
