Engine Serial Number Decode and Crankcase Ventilation
Read this for info on converting from draft tube to PCV (valve calibration is different for 170 vs. 225, not for earlier/later), and this post for what to do about the poor-quality chrome valve-cover-shaped trinket (it matters to the subject at hand).
OK. I looked. I will get an OEM valve cover...(got any?) SO if I get the OEM Valve cover, I can just stick the PCV on the breather and run a hose to the carb?
So I thought I had replied, but seems it didn't go... I will obtain an OEM valve cover and the PCV cap. If you have an OEM PCV, I would buy it from you...OBTW, still have the A/C unit you sold me in the box in the garage...getting close now and will be installing it this spring :lol:
