Overheating 360 new engine
You are going backwards. That shroud is no good. Pray you don’t have an electrical issue where you lose power to, or have to shut off power to those fans to conserve battery power. You will never get it to run cooler with that setup. Talk about the air packing up and not flowing though......good lord. I notice you never positively identified what water pump you are running. Six vane, eight vane, plate on the impeller?
Fans are not mounted with the shroud at all. I bought new high cfm fans and mounted directly to the radiator.
I think I responded to your earlier posting showing the shroud. My bad. I’m wondering about the water pump though. What you are running is a mystery. Whenever I read about issues like you’re having I always look at the number of vanes on the impeller. You “may” have an issue with coolant flow, maybe not. I suspect and ask based on what I went through a few years ago with my setup as well as others. Doyou actually know the number of vanes on the impeller?? If you don’t, I would be pulling the pump to verify things vs resorting to pulling the top end apart (yet)
Mounting the fans in that configuration will not help, you really do need the correct fitting shroud. Mother Mopar used them on every car for a reason.
Have you ever removed the hood and drove it? This would address some of your concerns.
150-175 degree under hood component temps is nothing to worry about.
You already have your water pump pulley machined flat on the face, all you have to do is mount the Manual Fan and spacer to it.
Before:
After:
Open it up, let it breathe. Plenty of room and not all crammed together.
Cool, Cool, Cool . . .
That’s kind of where I’m at . I have tried a different water pump . I believe it’s 8 vane . Also someone mentioned to modify the water pump which made a big difference for them. I have tried so many different things accept going major like head gasket or pulling engine ect. Folks have been so helpful.
I wish I could but no room anymore. I will post pictures tomorrow.
Your plight reminds me of this individual who just about changed everything trying to cool things down. Granted, it is a different animal but, actually the application is even more severe than most cars regardless of power output. In his case after tearing apart things replacing stuff he finally came round to the idea his pump was the culprit.
For your situation it may indeed be something else but if you have the time to read it all it is a good study or relatable:
Runs Hot - Out of Ideas
OK, the center 4 cylinders will run hotter than the outer 4. This s why there is a racing mod of drilling and tapping a fitting in the block and running 1/2 inch AN hose to the timing covers water ports.
There are a few other race mods of blocking off the water port from the back of the head and force water flow thru the heads water ports.
Slappy, have you tried a CLOSED air filter housing with some expanding Dryer vent hose to suck cold air from under the front bumper? Millions of Cop Car's had this well before the 'Ricky Ricers' found out about CAI.
Both years of the Little Red Express had this, 1978 and 1979.
I had a BBM I could not get to cool no matter what I did. I finally pulled the brand new Milodon water pump off and found the impeller loose on the shaft alowing the impeller to slip on the shaft. Went back to the stock pump , no more cooling issues.
I have tried 3 different pumps but I’m going to pull the water pump to confirm the blade configuration
This unfolding is painful to watch.
Like pushing a rickshaw uphill trying to gain momentum.
It's not that complicated, just sayin'.
Here’s the deal my friend. I get that it’s not complicated. The only thing I haven’t tried is going back old school fan as suggested by you. I get it but I have these things in stock. Also just because it works on your set up doesn’t mean it will work on mine. I appreciate your help honestly do but at the end of the day your at home thinking about it and I’m at home doing it.
definitely a good read and good info. I think i will look into the water pump type as well
I'm a lazy back reader. Did you say you've verified the temp with an IR temp gun? I mean.....I guess what I'm askin is are you SURE it's really gettin that hot? Like 100% sure and not 99%.
Without reading 9 pages again, I thought of something that may have an affect on engine temps. This applies to intakes that has the t'stat housing as part of the intake
What I found was this, with high flow t'stats such as Milodon, Robert Shaw, Mr. Gasket.
When these stats are fully open, the outer barrel drops down about 1/4-5/16". The water flows through this space. On some intakes, there is very little room for coolant flow because the barrel is close to the casting. If you calculate the areas, this area is actually less than the T-stat opening & causes a flow restriction. What I have done is ground away the metal under the lip that the stat sits on to remove any restriction.
Yes multiple times and different areas
I currently have a standard 180 t-stat
I got the heavy duty water pump today as suggested since I’m not sure what’s there because another shop replaced it . I will get in likely next week and will post the results. Thanks again for all the help!
EDIT TO REMOVE WRONG INFO
I think someone said that the March Pulley system you are running is at about 0.90:1 so OK for 8 fin. But if you had a 6 fin it might not move enough coolant.
If you scored one with the fin backing disc, a little better yet.
Just a reminder, the 8 fin A/C water pump is under drove at about 0.90:1
Are your sure about that? I thought the A/C cars generally had 6 blade pumps, but were over driven to increase coolant flow (and fan speed).
Clear explanation here:
Are we talking a performance engine here that’s running hot? Forget the 6 vane pump. Run the 8 vane, move the coolant......
