Torque converter, flex plate bolt applications
4spdragtop
Ontario Parts Unknown
Anyone know the application for the different sized bolts?
The 5/16 are the low-po big converters. The 7/16 will be on more street/strip oriented smaller "stall" converters.
I think the 7/8 long 7/16 are too long to be converter bolts. (Flywheel bolts?)
7/16-20 x 7/8"lg with 5/8" head are flywheel bolts for Slants & LA motors (only know because I just had to buy some!)
Thanks guys, yep as u described. I just checked spare tc and its 5/16"(need to find 2 more) and flywheel to crank makes sense as they would be from the 69 4spd.
Thanks!
BTW......I've got a ton of those TC and Flexplate bolts if you need any.
Left torque converter to flex plate. center are Flywheel to crank. right are flex plate to crank.
