nothingbutdarts
I have some from Summit coming, will see.
They were very hard to move. If the car was not finished they may work but if you are trying to easily move a finished car with one person, these are not the correct ones to have.
I’ve used the expensive one and you can move a car around with one hand. If you done mind pushing on your car as hard as you can then the HF ones will work fine.I never had any issues moving my cars around my shop by myself on the dollies, complete cars included. On a sloped driveway I needed two people.
But this shouldn't be surprising, how easy do you think it's going to be to move a 3,500 lb car? They're just dollies, they don't defeat the laws of physics.
Gotchya. Thanks. Yeah, Harbor Freight's casters aren't known for being the best.They were very hard to move. If the car was not finished they may work but if you are trying to easily move a finished car with one person, these are not the correct ones to have.
I wonder if they had a bad run of casters? I have an OLD floor jack I got from them when they first opened in Macon YEARS ago. The jack works GREAT but it rolls like crap. I need to get up off my butt and put some better casters on it. I have a better jack I use on the concrete floor, but I use the old one outside so it's not a huge deal.I never had any issues moving my cars around my shop by myself on the dollies, complete cars included. On a sloped driveway I needed two people.
Entirely possible. They're just cheap casters, nothing fancy. And clearly quality control is somewhere HF saves money. But they also exchange stuff pretty easily if you get something that doesn't work right, so as long as your comfortable taking something back if it's not working right then I don't see it as a big issue. We all know why that stuff is cheap, sometimes its gonna mean you get stuff that doesn't work. And yeah, something that costs 5x as much should work better!I wonder if they had a bad run of casters? I have an OLD floor jack I got from them when they first opened in Macon YEARS ago. The jack works GREAT but it rolls like crap. I need to get up off my butt and put some better casters on it. I have a better jack I use on the concrete floor, but I use the old one outside so it's not a huge deal.
I have to admit, I've had good luck with most things I've gotten there.Yeah but the expensive ones can cost $800 - $1,000 pretty easily. The HF ones are what, $140?
I think this is just a matter of expectations. I had no problems using the HF dollies to roll my cars around my shop even by myself. If I had a professional shop and a bunch of cars I had to move all the time then I wouldn't use HF dollies. But for a hobbyist with a car or two that has to rearrange their shop to do different work once and awhile they work fine.
It's like most HF stuff in my opinion. I wouldn't recommend a HF welder to someone that welds all day long for a living, that's not going to hold up. But if you need to weld in a couple of patch panels or a set of subframe connectors in your garage they work just fine and you don't have to spend 5x as much.
They also hold..................
........but the tiles have a diamond tread on them, lots of little bumps, and I wonder if the smaller wheels would end up sinking into the floor if left in the same spot for a long time..........
What are your impressions?? Do they work well?HF had a Christmas special for $109.99 and I went for it. 1300 lb. Capacity Self-Loading Positioning Wheel Dolly
I'm not really a big fan of HF but I purchased 2 sets from them. Just the dollies were useless but the one with the jack works great. Purchased them just to move a body around but then I had to move my Ford diesel dually and they actually did great. If you have bigger tires get one pair of the larger ones for the rear, they didn't make them when I got mine, but they are on the list.HF had a Christmas special for $109.99 and I went for it. 1300 lb. Capacity Self-Loading Positioning Wheel Dolly
I've already got one set and it works so well I wanted another. I don't have a lot of space for storage and my cars are parked like sardines in a can. The dollies allow me to rotate them in the length of the wheelbase and that is a valuable ability.What are your impressions?? Do they work well?
