Rings won’t fit in grooves on pistons.. HELP!
67charger383
Maryland
I’m partway through building the bottom end of my 383. I was just about to gap the piston rings but when I test fit them they won’t go in the grooves on the pistons…
Do I need special rings or something? 30 over TRW L2293 dome pistons and Hastings 30 over moly rings.
i most likely have the wrong rings there is different thicknesses look up your pistons and see what rings they use and compare with the rings you have
Seems like a simple problem...
Either replace the pistons or the rings.
As noted before measure the piston groves and buy rings accordingly.
Probably 1/16th rings vs the stock 5/64. About a .020 difference. Several sets of those on eBay list 1/16th rings.
You'll need new rings. But a simple feeler gauge check will confirm the thickness.
That piston uses 1/16, 1/16, 3/16, rings. Buy the appropriate rings and you’ll be set. What do yours measure?
You might throw a set of calipers on your ring lands before ordering just to make sure.
Do a couple of circuits around the ring lands with a piston ring land tool. Even though your pistons appear to be clean, you will be surprised at what comes out.
Al Bundy, a true Dodge Dart hero!
5/64 = 0.078125
1/16 = 0.0625
0.077125 - 0.0625 = 0.015625
Your trying to put a square peg in a round hole...
Another thing my dad always said...
" Measure twice cut once"
