273 style air cleaner base
moparlee
64 Valiant
Joplin, Mo
I've seen some folks selling some air cleaner bases over the years that look stock but yet have the big throat for newer four barrels....where can person find these?
Thanks for your time.
There was a member in TX fabricating them. Iif I can remember who it was, I’ll post it. I bought one for my 273/235 as I will be using a large throat carb or FiTech/Sniper. Nice part!
I made an adapter to use on newer carbs. Before that Dad used a circular piece if sheet metal from duct work.
I found a craigslist used a/mkt air cleaner, I think $15. Tossed the top and kept the bottom. Fits my Eddy carb perfectly!
You found a 10" one or just put an aftermarket on regardless of what size the bottom and top other than they matched, I guess?
I'll post what I have this evening......the top isn't chrome like 273's it's just a black one...like I guess was on some 361/383 and \6's...I need the bottom for it. It's actually going on my 241 Hemi on a run stand at this second, and it's running a 2-barrel carb. I have no bottom at all, but if I'm going to buy a base for it then I would rather have a one for normal 4 barrels and just use one of those plastic adapters that I have laying around for now while it has the Stromberg carb on it. Just trying to use what I have laying around and kind of leaving it Mopar since that's what I have.
You need a base the same diameter as the air filter.
The Craigslist air cleaner I got was smaller than the original, measures 9” across. I got me a Wix 42055 which is slightly smaller in outside diameter (8 3/8” O.D.)and is slightly taller than the original (3 1/8” Tall). Not perfect but close enough to solve my problem.
Yeah, there's the fancy way of doing it, and there's the easy, cheap way of doing it. No one can see the base when it's on the car anyway.
Just FYI, here's an original base for the hi-po 273 chrome air cleaner, also used with identical tops except for painted black instead of chrome on some early sixties 361 and 383 four barrel carbs.
I haven't bothered to paint it because it doesn't show. I guess some day maybe I ought to. Used with early small-opening Carter four barrels. It takes a 10 inch diameter filter. Despite its small diameter, it is an unsilenced air cleaner and was considered high performance because it flows better than a single snorkel air cleaner assembly. For some reason the top was also used on some slant sixes, with, of course, a different base for one barrel carb. (Had a guy ask me at a show how air got to the carb without a snorkel. Had to take it off and turn it over so he could see.)
For the Edelbrock carb on my 56 Plymouth, I used a base from an aftermarket ten inch chrome air filter. The base actually measures 9 3/4 inches across, so a ten inch filter sits on top of the outer ridge instead of inside it, but that really doesn't matter as it doesn't show anyway.
Here's what a hi-po 273 air cleaner looks like with an aftermarket ten inch base under it (motor's the 277 poly in my 56 Plymouth, carb's a 500 Edlebrock).
Thanks for the pictures it does look good.
Here is what I look for 53031547 assy. Then I cut and trim for the base, no extra holes very close to the original Command/Charger base, last picture.
Man...looks those are hard to find.
That looks like what I'm going to need to do.
They are not really that hard, they or similar air cleaners were on most EFI vans and pickup trucks. It is definitely more work, but they have no holes and use the 10" Commando/Charger air filter. They also have the opening for the Holley and later Carter/Edelbrock carbs. They are about the same hight as the original baseplate.
I just tried searching eBay and the net and came up with nothing....I'd do that in a heart beat if I could find one....doing the work to make it work wouldn't be a problem either.
I'll look next time I'm at a yard. You'll go crazy looking for MOPAR air cleaners on eBay.
