[Found!] Wanted: Drive Shaft for '63-'65 Valiant, '64-'65 Barracuda, '63-'65 Dart Wagon in So Cal
VV1-P
'64 Signet Super Six
Lake Forest, CA
Rating - 0%
0   0   0
Does anyone in So Cal have an early a-body drive shaft? The Ball and Trunnion type for the 106" wheel based cars?
Parts book says the same for /6 and 273. Also same for 3sp, 4sp, and AT. Not the same as Dart non-wagon since they are 111" wheel base. Not the same on '66 up since they went to the U/slip-joint in the front at that point.
Would like to pick one up locally. Thanks!
Thanks for the heads up. I just cleaned it out.
I thought I had scrapped this. It might be what you are seeking. From center of rear U joint to end of drive shaft, 48.5" That measurement does
not include the ball and trunnion. If this is what you want, PM me.
