I've read that stock magnum heads will do 210 CFM, at what rpm I don't know ?
Don't know enough about it to respondYou mean at what test pressure. I guess 28 inches as that is the de facto test pressure.
Contact Utawsome Performance. Marty, the owner has been working on these motors since they came out in 1992. He's a good guy & very knowledgeable about these engines. He'll have the answers you're looking for.I've read that stock magnum heads will do 210 CFM, at what rpm I don't know ?
I have a set of practice heads, I was wondering if they could be opened up to 250-260 CFM @ 5-6 k other wise I'll buy some new ones
Sorry, I meant .500-.600 liftRPM and flow are NOT related. That’s why I posted the test pressure.
That post was after drinking some Chardonnay, lolThat makes more sense then lol.
I think people have proven the pushrod pinch really isn't a big deal on these. Maybe @MOPAROFFICIAL will give us some answers.
www.forabodiesonly.com
If that's the case I stand corrected. Your wife is lettin you out too much.Over on Speedtalk there is a CFD thread and it proves the “pinch doesn’t matter” talk to be bullshit.
It matters. That’s why Chrysler (and everyone else) ends up with offset rockers.
LolIf that's the case I stand corrected. Your wife is lettin you out too much
It's a pretty broad brush to paint with. Depends on the ports design. You can have a port that works excellent and then open up that pinch as big as you can and watch it lose all of its low lift velocity which is airflow...as with a magnum head.If that's the case I stand corrected. Your wife is lettin you out too much.
