[FOR SALE] 1967 Barracuda power steering, column shift steering column.
Dmopower
Selling the power steering column from my car. It is a 67 Barracuda column shift automatic column. I was using this daily until last week when I installed a floor shift steering column I bought from a guy on here. The left turn signal cancel does NOT work and the reverse light switch is bad and I cut the pigtail off the broken switch for my car. The bearings in this are in good shape including the original stupid expensive lower bearing. Shifter lever and turn signal lever with screw are included. Wiring pigtail is still on the column and functional. 100 or best offer. Item is in Des Moines, Iowa 50316. Buyer pays shipping.
Free, Buyer pays shipping!! I'd rather give it away then throw it away.
.is the the same for a 68 dart? just had a friend call looking to change his 68 dart to power steering and an automatic. if its th same for a 68 dart it woudl be perfect.
I know they changed something in 68. The tube size for one thing.This 67 is a 2.25" tube most 68 were 2" But I don't know if this will swap right in or not.
