[FOR SALE] 1/2" tube low pressure side power steering pump and cooler from 66 Chrysler wagon
Dmopower
I have a power steering pump with bracket. I pulled this from a 1966 Chrysler New Yorker wagon 440 30 years ago. It's been in my shop. I may still have the cooler, but cannot find it at the moment. 125 obo. plus shipping. It appears to be in good shape. Ships from Des Moines, Iowa 50316
I found the matching factory C body cooler and included it in the sale ad.
A & B bodies used the same pump up through 66, although the brackets are somewhat different. The pulley looks the same. A/B mounting brackets will bolt right on. FWIW slants used the same pump with different mounting brackets depending if AC-equipped or not and a completely different pulley. The fitting on all uses a 5/8 hose as does the PS box. Steer and Gear provided all the above info when I discussed getting my pump rebuilt.
The PS cooler is U-shaped also using 5/8 hose. Steer and Gear said he’s never seen the PS cooler but knows some C bodies had them. Only C bodies had them if ordered. Here’s one mounted in my 65 Dart
BTW Steer and Gear paid decent money for a slant pump I had no use for. Maybe some of the above info helps with your sale. Good luck with the sale
Yup. That's the cooler I have. Great info. I thought maybe it has value for someone.
