Magnum 360 oildipstick tube
djhayes98
Member
Oswego Il
Replaced engine in my Duster with a rebuilt magnum 360...Having problems finding a new oil dipstick tube...Does an LA 360 tube work?
Thanks
Are you using the one in the timing cover? If so, Milidon and Blueprint Engines have them at Summit. I just bought both of them as I want sure what would fit there with all the stuff I've bolted on lately.
Thanks
The Magnum engines can use the same dipstick and tube as an LA. Specifically, you are matching the dipstick and tube with the oil pan being used. So if a car style center sump LA oil pan is used you install the LA dipstick and tube that normally matches that oil pan.
