I'd probably run hell out of it. It's a truck motor after all.No ridge at all. Had some light carbon but that cleaned up with a scotch brite pad and some atf. Engine only had 1176 miles on it since the rebuild. Just been sitting for a LONG time
Kind of what I’m thinking.I'd probably run hell out of it. It's a truck motor after all.
.068 the center of the piston.You never know. Maybe they did it to raise compression some. How far up in the bores do the pistons come at TDC? That would be a dead giveaway. If they are "around" .100" in the hole...... .060 to maybe a max of .120 it's stock. If they are higher than that, it might be offset ground. It was a popular way to gain compression in an otherwise stock engine.
That's not what we're lookin for. The deck clearance will be from the deck to the TALLEST part of the piston. In other words the NON DISHED part..068 the center of the piston.
The last stock late 70s truck 360 I had a part, the factory pistons were .160 down the hole,
I’ll check.That's not what we're lookin for. The deck clearance will be from the deck to the TALLEST part of the piston. In other words the NON DISHED part.
I get it. From the sound of it though, they might have offset ground the crank for more compression. If the dish is .060 below the deck at TDC, it's a possibility.Honestly though. I’m not concerned one way or the other. At this stage with stock heads, I really am limited by those so not much point is upgrading for what i need this truck to do
Very possible. But sadly, the three involved that would know for sure, are all with the Lord somewhereI get it. From the sound of it though, they might have offset ground the crank for more compression. If the dish is .060 below the deck at TDC, it's a possibility.
So it’s .0675 to the top of the piston from the deck. From the deck to middle of piston is .0145I get it. From the sound of it though, they might have offset ground the crank for more compression. If the dish is .060 below the deck at TDC, it's a possibility.
That's probably stock. But that's ok. You have a nice engine to work with.So it’s .0675 to the top of the piston from the deck. From the deck to middle of piston is .0145
Good enough for meThat's probably stock. But that's ok. You have a nice engine to work with.
It would be for me too! This is gonna be a fun project.Good enough for me
This one at least is mostly mechanical and paint. Very very little rust. And no external panel rust which is very niceIt would be for me too! This is gonna be a fun project.
I still would like to get down and get the one you have and some other parts.Nice score on the gate.
There’s a plug I found that I’ve never noticed or seen before today. I’ll get a pic tomorrow, hoping you might know what it’s for.I also have a plow set up for one.
They were painted either white or black.Anyone know if the rims back then would be powder coated or painted white?
I’m assuming painted
