Separating stuck inner tie rod ends
remytherat
Los Angeles
I can’t get the inner tie rod ends out with a pickle fork so I’m wondering if its ok to hit the center link with a hammer to jolt the tie rod ends loose, or whether I need a balljoint puller.
hit the side of the female taper of the center link where the tie rod taper goes a couple of good solid blows will pop it right out. You may need to put a second hammer on the opposite side to make a solid blow on it.
Yes, ^
I use a shorty sledge hammer as the "Dolly" on one side of the tapered casting, then give the other side a few good whacks with a 3 lb. hammer.
The theory of it is, it squeezes the tapered casting to "Squeeze" the tie rod end out.
Breaks free any minimal rust/corrosion to help pop it out.
Some PB Blaster penetrating oil as a pre-soak helps a lot too, like over night.
Good Luck
Load it with the pickle fork first, then a couple of raps it should pop right out. Make sure that you coordinate the hammer blows so that you are not stressing any other steering component. By loading it with the fork, a lighter hit may work.
Of course, Harbour freight probably has the right tool for the job cheap. That would be my first choice.
Thanks for all the help. I just went and got the tool. Used a pickle fork to make space for it then put the tool on and they popped right out.
That was smart. Normally, I do my best to avoid hitting things with a hammer. Although sometimes that's all there is, but I leave it as a last resort. There's always a tool "for something".
Thanks for letting us know how it came out. Sometimes we are left wondering.
and sometimes that tool for one thing can be a tool for something else with a little creative thinking.
i'm all for choosing violence, but if there's a reasonably priced tool that will get the job done and not wreck anything else them i am all for that.
Buy NOTHING from harbor freight
Yeah, sometimes beatin the snot outta somethin is downright therapeutic.
Hammers are for driving nails and beating the **** out of a pos when you are pissed off. With the exception of a body hammer. I don’t use one for any thing other than the 2 uses I stated.
There are places for the crap they sell. Separating 4 tierods in a lifetime would qualify. :)
I'm a tool freak, but even I have a couple of the el cheapos for 1 off jobs, and tool modifications.
There’s not many feelings better than walking in to HF buying a cheap set of wrenches, then getting home or the shop and taking a death wheel to that brand new wrench to make it “custom”
Sorry, my cordless drill and impact wrench beat Milwaukee and dewalt all over the place. (Not the drillmaster garbage) They are all made in China anyway.
My folding harbor freight trailer is the cats ***.
I do so much front end work at work that my 3 lb hand sledge has become the first thing I grab after the fasteners are off. these days it's mostly 3/4 and 1 ton Ford vans at work.....
For others that may come across this problem an old shop teacher taught us to use the ball end of a ball peen hammer. Worked like a charm most of the time
