kennethjohn09
Member
Has anybody bought the transmission mount at usct store?
HDK B- body version just out (first three pics)......no floor cutting
HDK A body version in the works. (last picture)
for 8HP70/90
includes adjustable height transmission mount reinforcement and install template
Does this work with the factory k-frame or does it require the motor to be forward and down a little?
@HemiDenny Very good looking! Will that mount also support the A500/A518?
Ok here I am Getting ahead of Denny lol I should have just called you. Looks like I am on the right path OEM k frame I am using with the Hooker black heart and modify the hoop for the NAG 1 kit. I will keep sharing can't hurt but I may be calling you. Thanks!It puts the transmission with adjustable cross member reinforcement as high as possible in the tunnel without major surgery. The crossmember transmission mount is adjustable front / back and up / down.
If I was doing an OEM K build, I would use the HDK transmission mount / A body version, do a slight mod to the tunnel (pictured),....and make it work.
So my issue with this system is it's for a Hemi swap and motor forward. I really don't like the idea of forcing more weight to front 3 inches. Hemi its long and bigger makes sense. But I'm using a JVX adapter 360 engine stays put and trans mount moves with torsion bars in place. Cost is a factor for me the USCT system also requires the tunnel system.
