Carb throttle idle screw not adjusting SOLVED
nickname
Member
Finland
I have a Carter bbs carburetor and for some reason when it switches from fast idle to normal idle, the rpm does not drop. Looking at the screws closer I noticed that the idle screw is not even touching anything. Screwing it whole way in does not help either.
What could be the reason?
What I would do is start disconnecting linkage parts until I found what was holding it open.
If I didn’t find it doing that I would make sure the throttle plates inside the carb were centered when closed.
Thanks for the replies! I'll check these tomorrow when I have more time and update you after that.
It is common for those to stay/stick on the fast-idle cam, due to either the cam sticking, or the choke is faulty, or the choke is not getting enough heat.
Try a penetrating lube on the cam. If that don't do it remove and polish the pivot screw, reinstall it dry.
I have, many a time, zip-tied a weight onto the vertical link, making it heavy enough to trip the cam.
I would disconnect ALL linkages going to the throttle lever and see if it will fall to idle.
Remove the rod circled in red. That's the offender. That rod installs on the choke, not the throttle lever.
Sooo...it was the throttle linkage cable. Now, I just have to figure wheter to replace the cable or get it unstuck.
Thanks for the help everybody!
Edit: Adjusted the throttle cable from this bolt and now the problem is fixed.
I think that picture is a bit deceiving at first glance. I thought you were correct, but a real close look shows it is hooked up to the choke. I think it's correct. Or I'm just misunderstanding completely.
I think you're right!
