Need a little help
Frank Dinatally
Pennsylvania
Hi Everyone
Want to say thank you all again for all your help. My question this time is under the rear window on a 65 barracuda is there a panel that covers the metal at rear bottom of the big glass. I have been searching pics to see this part clearly. Any help is appreciated Thanx Frank
Inside Sorry
It is shown just under roof at back
There was plastic trim that covered the radiused ends where the round holes are. To my knowledge, there was never anything covering the center area with horizontal slots. Here's a similar thread with some pictures:
'65 Barracuda Interior moldings under rear window
Need to Remove those to gain access to the Rear Window Trim, I think they might be Riveted on?
There is no trim on the flat straight area, just on the corners. On the straightaway, there’s body plugs that snap into each hole to keep dust and dirt out. That’s it tho, no trim.
He has an early version of '65 builds. There are no body plugs that snap into the rectangular slots as far as I know. If his car has round holes across that straight section (as does mine), then yes there are body plugs for those holes.
