65Val
Average Length Member
Patient::: 74 360 block and '66 904 automatic bellhousing with early 904 (small hub) converter with B+M weighted flexplate ...on engine run stand. I cannot stop the starter from grinding. I have tried several starters to no avail. Is the tin spacer/cover required for proper starter/converter alignment?
is going on.
Thank you! If you have any other ideas, I’m all ears.
