[SOLD] Rusty Crusty Dent & Ding Sale
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
I pulled all these parts of the 67 & 68 Barracudas I am parting out. Prices + shipping from FL. Paypal F&F or PMO .
#1. SOLD. SOLD
Stripped the seats down to the frames. Has surface rust but not rotted though anywhere. Frames , seat backs and hinge hardware included.
$150.
#2
SOld. Sold
Seat brackets and sliders. Sliders move freely, the brackets are a little rusty on bottom and one has a hole rusted through.
All studs intact. $75
#3
sold. Sold
68 Power Steering Floor shift column. $125. Pretty clean and in good condition.
#4
68 Power Brake Booster Brackets. $30. Moves freely
#5
Rear seat parts . $25 for the lot.
Scroll on down for more parts. Claim parts by # listed ! Thanks for looking.
$50
68 V8 SB after cleaning I found some rust through .
Right front , needs a patch job.
#7
$50
67 V8 SB modified for BB. Good useable condition.
Note how it's squared off for the oil pan clearance and notched for the oil pump.
#8
Upper A arms good condition , will need new bushings and ball joint . $40 for the pair.
GONE !!!!!!
#8
Lower control arms. Good condition , will need new bushings also ! T bar adjusters moved freely.
$40 a pair.
#9
OEM 67 Dash pad. If you can use it, fix it up some .$50 All mounting studs intact.
More parts below ! Check em out .
All studs in tact. $40 Left side fender bling
#11
SOLD SOLD
$75
Deck trim. Not perfect ( but what is ) I will include a few of the clips I salvaged so you can figure out what is needed.
#12
$30 for the pair Crusty but intact.
#13
Fastback trim under side windows. Door trim has some small dings from removal 1/4 glass trim is ok.
$25
#14
$35 A little pitted but not terrible
#15
69 Tail panel . Has some dents and dings. Mostly on the upper & lower edges
$70
Thanks for looking , please claim by # listed . I can send more detailed pics if wanted.
Do you have any of the other power brake parts?
Is the pedal assembly different than a non PB one?
Thanks.
I don't know either, but the linkage sure is.
How about a booster?
Even a core.
I'm thinking about converting my 67 wagon to PB.
Pretty sure this stuff will work.
Thanks.
Even a core.
Yes I still have the booster core. PM me if interested in this stuff ! Make you a deal .
Mines a 70
You can buy them online. You may need to use your core. Finding a original one may be more difficult to find and more expensive. Also, they would be fragile and break easy as to crack. I never bought an aftermarket one, but I have seen some good ones and some bad ones. Do your research.
I'll bet the 67 cuda dash will mount right up where 70 mounts. The difference is 67 has an ever so slight lip/ledge in approx the middle.
The 68 cuda dash is 3 pc and the ends on top piece are tapered to fit in the 2 bottom pieces.
69 and 70 are the same, I think the 67 and 68 are different. 67 may even be different then the 68'.
