[WANTED] Would like to purchase a fixed mast antenna
drodg58
indiana
Rating - 0%
0   0   0
I have a 72 Demon 340 with an adjustable antenna but I believe I should have a fixed mast antenna. I am looking for a nice and complete with base etc antenna. Thanks
Look on e bay that’s where I got the whole set up and cable
or strip classics
Thanks but that is telescopic not a fixed mast. The 72 A bodies had a fixed mast antenna
the place is called strip classics on e bay motors this is a one piece antenna
Originally AM-radio-equipped cars would've had a 76.5" telescoping mast while FM had a fixed 31" mast to maximize FM reception. Both are shown in the 1972 parts book.
You only need to replace the mast; the base is the same between the two. It was common for dealers to replace telescoping masts damaged by garage doors, car washes, etc. with the stronger solid FM mast.
thank you
