even if you use a magnum crank?the mag pistons need mag rods because they be thinner on that end.
so you'd be skinny-ing up some LA rods and then rebalancing the whole encharito.
enginetech P3004(8)Do you have a part number for those pistons? Every time I try looking those up I can only find 360 pistons in general. Sorry, I didn't mean to highjack the op thread I'm just trying to get the part number of those pistons.
HiJack away.Do you have a part number for those pistons? Every time I try looking those up I can only find 360 pistons in general. Sorry, I didn't mean to highjack the op thread I'm just trying to get the part number of those pistons.
uhhh... depends?even if you use a magnum crank?
oh... my friend... not who you want to give carte blanche to on a thread....HiJack away.![]()
yeah, people pay for lighter rods. magnum rods and pistons on a LA crank? I"ve not mixed and matched the internals of the LA/Maguhhh... depends?
i know that the mag rods are lighter. so i guess it would come down to what the bob weight was with the mag pistons if you were trying to keep the LA rods.
but then you're into a whole: why would you use LA rods with mag pistons and crank...
you can install rod and piston assemblies on either. but, again rebalance (to do it right).yeah, people pay for lighter rods. magnum rods and pistons on a LA crank? I"ve not mixed and matched the internals of the LA/Mag
i've always kept LA, LA and Mag, Mag when it comes to the inside. I like the Magnum blocks and cylinder wallsyou can install rod and piston assemblies on either. but, again rebalance (to do it right).
you can do a bottom end boogie mag to LA straight across even.
the difference is the pinboss in the pistons and the small end of the rod-- LA wider, mag narrower. so it's keep it matchy-matchy or skinny up LA rods to fit mag pistons.
if you change components, you change the bobweight and it needs a rebalance.
totally not confusing at all, right?
oh, and don't forget... the rings are different too...
I get ya, if shooting for 1HP/CI or more.Mill heads and block only to square them up. Manage compression with pistons.
I tried to message you, but you box is full.You can take .100 off a stock block.
You can take .200 off an X block.
You can take .300 or more off an R block depending on which version of the R block you have.
You will need to machine the intake manifold when you start taking that much off.
“With bows of Holley- falls-la-la-la?”Deck the block.
"Not shooting for 300 HP here....." Your words. So here's my advice. Have the block deck skimmed to just clean it up and level it parallel with the crank center line. Get the heads milled .025". Then, just do a basic rebuild. Bore if needed, but if not, reuse your pistons. You're talking about buying KB pistons and your goal isn't over 300 HP? Ridiculous. You can make a low compression engine run great by advancing the cam some and putting a good loose curve in the distributor. With a decent intake like a Weiand Action Plus, a good carburetor like a 650 AVS2, a nice mild camshaft maybe one step down from the Comp 268 and headers, you'll probably be all over 300 HP and you may not even need to bore it.Some 25 years ago I had a 318 rebuilt. All stock but a “RV” cam. The project went away that the engine was intended for, so mounted it in my ‘32 Dodge PU.
I asked a few questions on a site I’m a member of for 10 years, many suggested coming here.
Well I pulled the intake and heads-engine will get taken apart anyways to clean a line it back up) and the deck is off, each side around .010, that and the pistons are .095-.105 in the cylinders.
So here’s my options, spend up for the KB pistons, square and mildly deck the block. My heads are open chamber, rebuilt, and will just keep them.
I figure I could save a few bucks over balancing the rotating assembly and KB pistons,plus some squaring and decking, and compare to a heavy deck cut and run the pistons I have. This would just be deck and intake milling.
No balancing required. That’s a savings I referred to.
So with that in mind, how much can you deck a LA 318, still do manifold milling to get it to line up? .040?, .060, etc.
anyone experience this, or just square up the block, run the taller KB pistons.
Not shooting for 300 HP here, but I just can’t sleep well knowing 8:1 CR ratio is turning the crankshaft. And yes, I live through the neutering of the engines in the ‘70’s. My beloved BBC LS5 was cut 75/80 HP from1970 to the 1971 year.
Thanks.
You simply cannot tell some folks how insignificant a change in compression will make by itself. They just will not listen.you're worried to death about a point or so of compression but haven't addressed the cam what so ever.
are you keeping what's in there? if so, what is it?
if you aren't, then there's a whole wide world of options to wade thru. there are a bunch of key factors that would weigh heavily on cam choice: vehicle weight (from my understanding it's in a 32 pickup?), transmission, gears, use/driving style.
you can build a mean little ripper with so called dog water compression and the right cam, intake and carb (and headers). it'd be no fun in a big ol' boat but in something light it'd do just fine and dandy.
The .1, .2 and .3 numbers you listed, how did you find this information, or by sonic testing decks?
Thanks
Thanks
Cause the CR, VE, Cid etc.. police always come along to scare them off.You simply cannot tell some folks how insignificant a change compression will make by itself. They just will not listen.
That and all of the magazines telling the masses they can run 11:1 on the street on 87.Cause the CR, VE, Cid etc.. police always come along to scare them off.
Thanks.
That, plus I feel some get super focus on only one/two pieces of the puzzle but don't/can't look at the overall picture. And the 2 puzzle pieces most seem to over worry about is cr and velocity not that there not important pieces but seem to paralyze people from building generally decent mild low budget engines.That and all of the magazines telling the masses they can run 11:1 on the street on 87.
