[WANTED] Windage Tray Bolts 318/340
FYI....when you find some bolts, they will likely be from a 340. Those will fit 340/360 main caps as they are. If you use them on 273 or 318 main caps, you will need to use a few hardened washers under each bolt head because the main caps for those engines aren't as tall as the 340/360 caps. They work fine in 318's, but just use the hardened washers. Good luck with your search.
I'm glad you had that set and thanks for doing the legwork. 7/16 and 1/2 look very similar in ebay photos but not the real world. Where's the beef? In the small block mopar main cap bolts. Thanks for the info!
That 289 K motor clone is the the only non Mopar engine I kept.
Fellas, this is a wanted thread and let's not have a chat session here.
