Timing Mark Dilemma
The Dart GT
1963 Dodge Dart GT Convertible
USA
On my engine reassembly, I'm stuck with the timing. The cam pin (and cam gear slot) is pointing straight up and is exactly square with the top of the block. The crank key is pointing exactly straight up. The number one (and number six) piston is exactly TDC including any adjustments for dwell. Why aren't my timing marks aligned on the gears? If I move the camshaft slightly clockwise so the marks line up the camshaft is going to be cocked slightly to the right and is no longer pointing straight up. Is it more important for the cam and crank to be in the correct position or is it critical that the marks line up too? Thanks for the help.
I believe you have it in time. Turn the crank one tooth clockwise and I believe you'll find it will align the dots on the crank and cam sprockets. It will only do that ONE WAY and if it aligns, then it's correct. I think somehow you THINK it's a TDC, but it's not. Can we get a picture of the piston on #1?
The slants my machine shop buddy built for me where similar. He bought 3 different gear/chain sets and they were all off by a half tooth. We degreed the cam and it was dead on so he marked the gears to be aligned where it was. Yes it was a 1/2 a tooth off from the (aftermarket) factory marks. All I can say is degree it to be sure.
If you look at the OEM FSM photo.
The dots are on the peek of a tooth
Red and blue
In the photo of your gears and chain it's peak (red) and valley (green) (1/2 tooth off)
BUT.... that does not mean that the keyway in one or both gears is not adjusted to make it work right.
Rusty, Thanks for replying. You've been a big help so far with my build. This is a 225 and the pistons are 0.1585 below the deck. I know that's a little low for some people but I believe it's within spec. I'm using the original rods so that's how the original engine ran. Believe me when I say I've rocked it back and forth and back and forth and the piston is as high as it gets.
Notice in this photo I can get the marks to line up but the cam is cocked to the right and NOT straight up or square to the block.
Red and blue
I have a set the same as his and my cam sprocket is marked EXACTLY like his with the dot between two teeth.
Where does it specify in the service manual about the cam sprocket being square with the block? If the alignment marks line up, and they do, then it's right.
I got it out of Doug Dutra's manual. I think I'm starting to feel better already.
Well, as others have said, the only real way to know 100% is to degree the camshaft. It's a simple process and one that I would not leave out.
Okay. I'm going with crank key pointing straight up and the #1 cylinder at TDC and leaving the marks lined up like in the second picture. On to degreeing the camshaft. Thanks again for the help....and stand by. I'm sure I'll be back!
Keep in mind though, that dot to dot IS 180 out. TDC for #1 is crank dot pointing at the cam sprocket and cam dot 180 degrees away from "lined up" with the crank sprocket. Dot to dot is on TDC for #6. It's shown dot to dot in all the manuals for ease of aligning. But when you go to install the distributor, you need to rotate the crankshaft ONE complete revolution to get it in the #1 TDC position.
Dot to dot is ALWAYS the way I do it simply because it is far easier to see when they are properly aligned. Just turn the crank one turn, and you are on TDC again, no1 ready to fire.
Another thing, and Rob maybe you know? "Back in the day" cams were often checked at "split overlap." This means when either 1 or 6 is on the opposite stroke from firing, the exhaust and intake are both equally open. That is, dot to dot, no1 valves would be "split", and 1 turn around, no 6 valves would be split. THIS MAY ALWAYS HAVE BEEN a myth and incorrect, as nowadays with the cam timing used, there "is no" split overlap that is correct so to speak, with V8s. I don't know about stocker slants, 4's, or other 6's.
I was missing this VERY good point. When I rotated 180 for #1 TDC, (with the dots opposite) now both the intake and exhaust lifters are dead even (open). (I have stacked the lifters so I can lay the straight edge).
Actually, the two lifters for #1 should be all the way down (closed). What lifters are you using?
Exactly.
People forget that cam/engine timing is separate from distributer/engine timing.
2 separate procedures
Just stumbled on this in 73 chassis manual.
Note the red on the cam sprocket is between teeth.
The crank sprocket blue is on the point
And the keyways green are not vertical.
Maybe a change in some year.
You are correct. They are all the way DOWN, which means the valves are closed.
What you are actually looking at in the picture are two rod pins stacked on top of each other so I can get the tops up out of the block high enough to lay a straight edge across the top. Turns out the piston pins are the exact same diameter as the lifters. Who knew?
